i need help with the torque reduction.
only on 3. gear from 2000-2700rpm the throttle will not full open at WOT. you can see in the log file if im over 2000rpm and go to WOT the throttle will not open full but if im under 2000rpm got to WOT the throttle opens full.
if this happens torque source 1 - Transmission torque truncation will be active.
i was maxing the torque truncation and clutch protection tables but still the same problem.
ist a 2015 Mustang 5.0 Manual
any ideas how to disable the torque reduction?
421520torque reduction.hpt
