Transplanted into a 1972 LeMans. All stock. MAF in a 4" tube. Has really bad idle surge. Ive done some searching on tuning the E78 and am needing some guidance. Thank you in advance.
Post Tune.
Post Log.
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
having same issue in a 5.3 swapped 48 chevy pickup, did you get the issue fixed?
MAF settings are wrong for speed density tuning.
MAF fail high, set that to 2hz and the low fail to 1hz, then the 3 MAF dtc's to fail on first error.
Is the rest of it stock or does this have a cam in it?
Completely stock engine. I will adjust maf settings and report back. Thanks!
Changed the MAF fail settings and still has same issue. The only issue is the sure while in park or neutral, if its in drive or reverse everything is perfect and it drives normal, just has a terrible surge in p/n.
