I have a gmpp crate engine controller package (ls3/525) and a n/a 427 LS3. Using the as-provided tune and the MAF plugged in, the car starts fine, idles fine and drives fine. The only problem is ultimately I need to go to speed density because I am using an ITB intake manifold (Harrop LS3 DBW ITB manifold). I would like to go in baby steps - make sure the as-provided tune works with the stock intake manifold (check), get it into speed density mode and get the car to just idle on its own and drive up/down the driveway, and then put on the ITBs and cross my fingers (with final tuning being done on the dyno ....I would be thrilled if the car could start and move forward/back on its own with the ITBs)
My understanding is that to get the ecu into speed density mode I want to set the MAF frequency fail high and low to 0hz and P101, 102 and 103 to 'ses off', 'error mode no MIL'. However, what I don't understand:
(1) How do I determine if the default parameters in the ECU are 'okay' for speed density (okay meaning it can idle on its own and move forward/back on the driveway) ... I have no idea what to look for
(2) How do i determine what bar MAP sensor I need to use - the engine came with a camaro 3 bar MAP sensor but if the ECU is setup to only use the MAF maybe they just stick on any MAP sensor they have? This one is doubling confusing because under 'VCM enhancements' there's options to upgrade to 1/2/3 bar speed density (but 1 and 3 are greyed out, only 2 is available). so I don't understand why this exists if failing the MAF causes it to go into sd mode. do I want to upgrade to 2 bar SD (and then replace my 3bar map sensor with a 2 bar, or would this impact my base MAF tune)
(3) Since the air temperature sensor is built into the MAF my understanding is you can fail the MAF and the temperature sender will still read using it. How critical is it it gets an exact reading of air temp? is more-or-less okay? I was thinking about relocating it somewhere around the engine bay away from heat.
I've attached my base tune file hoping to get some guidance about the speed density - i.e., if i fail the MAF will the ECU go into speed ensity mode, are the current parameters 'okay' to get it to idle, what bar sensor should i be using with the given file, do I want to upgrade my OS to 2bar speed density?
917_STOCK_tune.hpt
