Ive got a buddie with a mild cam and bolt on ls2 tbss, starts ok warm ( not perfect ) . cold it just cranks and immediately dies as it starts.
Has stock C6 ls2 vete injectors.
tried maf only and speed desnity, issue seems the same .
I have added about 25% startup airflow , and added some air to the minimum air tables.
I've also tried adding some cranking spark. One table ive never messed with is the startup flare spark.
The only thing I dont like on the truck is the guy has a 3.5" silicone elbow stretched on the stock 90mm throttle body, hes a cheap bastered though and swears its fine but I think the coupling could be cracked and leaking.
would a leaking coupling at the TB cause the issue i'm having ?
anyways, heres the tune file. Please look it over and let me know if you see anything ?
Bill basic,ls2 injectors , ls7 maf only , YANKconverter settings i final.hpt
