Results 1 to 15 of 15
Thread: Question about VE Tune --AFR error in open and closed loop
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    E40 SD Tune. I changed pulley size on the Maggie and retuned. I thought I got the primary VE table pretty close. After going to closed loop, the numbers changed a bit. Is this pretty normal?
    The open loop table is #1 and the closed loop table is #2. Thanks for comments.
    2013 Silverado 5.3, 6L80k 8.8
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Evap system turns back on when you go back to closed loop, so that can (will) affect fueling to some degree
    Not unusual at all
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Jul 2012
    Florida
    1,459
    Thanks!!
    Advanced Tuner Ranger6202's Avatar
    Oct 2013
    Wyoming
    346
    Don't forget that your WB's won't always read exactly the same as your NB's. Few variables are to blame; brand, service life, power source, etc....
    Custom '85 Crew Cab Short Bed Lq4 swap
    '06 Turbo Vortec Maxx
    '87 Military K3500 LQ4 swap
    '96 K1500 lq4 swap, Howard Cam (216/224 @ .050, .551/.551, 114), Centerforce Dual Friction
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Good point Kasey. So to validate your WB vs NB redings, set the tune in closed loop, and log WB value. Run car up to about 20 -30 mph and look at your wb readings. They should be hovering around stich as that is what the NB's are commanding to the PCM. If the WB value is higher, work the offset value in your custom PID down until it is hovering around stoich. If WB is low, then rais the offset value. The good news is you can do this all with the same log in the confines of your home after you logged the data :-)
    If you don't have a custom PID (you are using one of the HP Tuners canned WB PID's) and the values are the in line then tht is not your problem. If they are off, then set a User defined WB PID.
    Ed M
    [email protected]
    Jul 2012
    Florida
    1,459
    Quote Originally Posted by mowton View Post
    Ed M
    The light is starting to come on now. I replaced my narrowbands a few weeks ago and I guess they are a little different than the old stock ones.
    I'm pretty sure the wideband was a couple of tenths low so I will adjust my offset. It didn't register at the time. I will check and make another log and see what difference it makes. Thanks guys.
    Jul 2012
    Florida
    1,459
    Yep, Had to do a custom PID for the NTK and adjust the offset. Now the wb and nb read about the same. I had to adjust VE again
    Ed, thanks for the info.
    Oct 2013
    Wyoming
    346
    One thing to remember, 5% is more than acceptable. You'll find that on any given day you'll dial in the VE or MAF to within 1%, only to find a few days later it's trimming 4-5%. This is totally normal as conditions have changed and will continue to change. A few days more and that 4-5% may now be -3%.
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Lakegoat View Post
    My pleasure...glad it helped. That was my tip of the month on my ERM Performance Tuning Facebook page last month.....
    Ed M
    [email protected]
    Jul 2012
    Florida
    1,459
    Thanks Ranger, I'm done with the Primary VE. I thought it would be a good idea to give it another look after changing the offset. Boost VE is hard for me to get done. Can't hit many cells on the street--in Mexico.
    Ed, I will have to link to your facebook page.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Pay attention to what the WB is bouncing between when the NB's are cycling. If they are cycling and the WB is going from say .97 to .99 then I would change the offset by about .02. That'd get them to around .99 to 1.01, which matches up with the NB's IMO.
    Either way, it should be close without doing anything...
    Jul 2012
    Florida
    1,459
    One of these days I will figure out how to switch this thing to Lambda. Right now, I am stuck in 14.7 land.
    Thanks Schpenxel
    Mar 2007
    Florida
    3,773
    Lambda is the only way to go..... :-)
    Ed M
    [email protected]
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Indeed!
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Jul 2012
    Florida
    1,459
    If I can ever get a new readout box from NGK (I broke mine--let the lift down on it) looks like all I have to do is select Lambda with the select button--that is busted. Still works, just can't use the button.
