Only thing I see done to the idle section is min airflow increased by 1 g/sec. Surprised that would cause the issues you're having though. I'll check log out later.
It's switched to MAF only, SD is disabled totally
MAF table messed with a little bit up top. Changes are small until ~12,000hz
Injector flow rate is a few % under ID's data. I guess he was trying to make it fit? Not real sure. Offset/short pulse adder tables are right
Rev limiters increased to 6800
LTFT's disabled
PE set leaner at low RPM's
High octane spark table is all over the place? Some spots are 15* higher, some places 15* lower than stock (mostly odd/extreme ends of the table)
Low octane spark table is matching high octane table now. Not a fan of doing it that way but a lot of people do.
AFR spark correction zeroed out
IAT spark table has a big section zeroed out
KR decay rate increased quite a bit at high RPM's (5 to 6x factory values). Seems high for me.
Burst KR disabled
Lot of small transmission tweaks, looks like torque converter lockup pretty much disabled for the first couple of gears
Here's a stock CTS-V tune you can compare to
1443633356.hpt
