Just started toying with my buddies car and still haven't quite understood the boost control setup. Found an ATS tune running 22psi and copied the boost setup from one tune to the other. itll hold 22-23psi from 3rd gear up to 130mph but it doesn't hit full boost in first or 2nd? My assumption is maybe something in traction control but I turned most of it off.
I thought by raising the wastegate duty cycle would increase boost, but ats tune had lower duty cycles saved. Not exactly sure which table made the change and where to focus at. Car use to spike 18psi then fall off to 11psi and spike again between gears. Now have 22psi through rpm range in each gear but 1st and 2nd.
I'm sure there's more PDI's I need to insert to log. Just played around for about an hour
