Results 1 to 4 of 4
Thread: Did not enter PE while it should have
    Okay gents, what am I missing here:
    PE Enable MAP = 70 kPa
    Actual MAP = 175 kPa
    Enable RPM = 2100
    Actual RPM = 4200
    PE Throttle = 44% @ 4000 RPM
    Actual Throttle = 63%
    Ramp In = 2.000
    PE Dealy RPM = 2300
    set your enable rpm to 0 and see if that fixes the issue. i know you dont want to hit pe at idle or just above, but youre foot can dictate that. all my tunes, including my stocker, are set to 0.
    Dec 2014
    Palmetto, FL
    874
    Maybe log throttle pedal position and actual throttle position and compare. Make sure that both exceed your TPS active point in the tune first.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    there is a write up on this somewhere. Search for it, but long story short you will have to lower the commanded pedal position. say start at 55% then decrease gradually to 25% at 4000 I usually plug my own numbers but you can interpolate between the two. THere is a "lag" in power enrichment
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
