I ordered the ID1300 injectors for my '11 GT500. I found the Ford specific data on their website. I am not seeing a spec for "Pressure Drop Reference". Has anyone used these and know this setting?
Thanks!
Thanks!
You must be making some real power with your 2011 to need ID1300 injectors. I'm over 700 hp with my 2013 which has ID1000 injectors. I'm in the 50% duty cycle range.
If you run E85, you'll need/want the flow and ID claims the 1300's have better low PW linearity than the 1000's and are more alcohol compatible. They almost tout them as a replacement for the 1000's. It is a big injector though. I'm getting ready to do a SC 05 with some so we'll see how it goes.
Jaime
Yes, will be running E85. They are definitely big. I have yet to get an answer from Injector Dynamics re. "Pressure Drop Reference". I can assume 39.15 but I hate to make assumptions.
On my 2010 GT500, I set the Pressure Drop Reference to what my mechanical fuel pressure regulator is set to under the hood...60 psi in my case as I'm trying to stretch out the ID1000s on e85 while I save up for 1300's
