I am way new to this so please bear with me. 2014 Camaro SS Auto with a Procharger. Done and running fine, just learning the inner workings as a hobby interest.
I setup the scanner to what I thought was correct, but my MAP readings I dont understand. Wondering if I have it setup wrong, on some logs I get negative KPA in the map and at other times I have gotten readings under boost of it maxing at 120kpa
Either I dont understand what I should be expecting from the MAP (thought 100 was normal zero vacuum and anything less is vacuum, more is boost)
My config and logs attached - would love input if config setup wrong - thanks in advance for the schooling
