Results 1 to 6 of 6
Thread: Long Crank before starting , after walbro fuel pump install
    Oct 2014
    11
    Question Long Crank before starting , after walbro fuel pump install
    Just installed a Walbro fuel pump to my Silverado and it cranks long before start.
    Any help on what the problem could be? Any tables I need to mess with?
    Thanks , any feedback would help.
    13,564
    Checked fuel pressure yet?
    Maybe you have to prime it a few times or the regulator isnt working right.
    Sep 2012
    PA
    46
    Some walbro pumps don't have internal check valves. So you're starting with zero fuel pressure every time you turn the engine over. You can install an aftermarket check valve right before the fuel rails if this is the case.
    Tuner seven ends's Avatar
    May 2007
    Houston, Tx
    155
    Quote Originally Posted by atx View Post
    I noticed that about my Walbro too. I added another second to my prime time under Fuel System > Fuel Pressure. The main thing to remember is turn the key on for the amount of prime time before you actually hit the starter.....makes the most difference. I also bought a check valve I am adding when I change to a hybrid return system in a couple of weeks.
    2010 Avalanche 4WD; AES 390; Mast LS3 heads; VVT Cam; ported TVS2300; Overdrive 8 rib pulleys; 2.7 snout pulley; ID1000; LS3 TB; WB 450; Twin MM cans; built 6L80; CircleD Triple Disk, CSR flexplate; Trucool 40K; Aeroforce Dual; AFX
    Oct 2014
    11
    Increased prime time but still have the same problem.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Turn the key to the "on" position, count to 3(sec), then start the engine. I have my prime set to 6 seconds and do the delay start thing. Don't get the check valve with the flapper valves. They just blow out and shut off the fuel flow.
    2013 Silverado 5.3, 6L80k 8.8
