Results 1 to 7 of 7
Thread: 2003 Tahoe 5.3 SD Tune with 70mm turbo at 7psi
    Sep 2015
    10
    I'm hoping someone can give me some advice on continuing with this tune. We have a relatively stock 5.3 with a 70mm turbo limited to 7psi of boost. I spent a lot of time reading through previous posts and how to's in order to get started and to get where I am. As of now, it is running a 2Bar SD tune in open loop. As of last night, the first pull seemed to go quite well with no knock but by the last log, it started to develop some KR. Any advice would be greatly appreciated. (Sorry, if I'm doing something completely wrong let me know. I'm learning as fast as I can being my first attempt at this.) Thanks in advance!!
    TahoeBoost.cfg
    2003 CHEVY TAHOE 2BAR SD.hpt
    Final 2.hpl
    Final adjustment.hpl
    13,565
    I do think nearly 13 AFR commanded is pretty lean.
    Sep 2015
    10
    And this may be another issue. I have both the pe and be tables set but the commanded never shows what it should calculate out to.
    Sep 2015
    10
    Actual afr is a lot better than what it's showing in the logger for commanded.
    Sep 2015
    10
    Anyone have any ideas? I'm sure I'm just missing something simple.
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Your running too lean. Try this tune. If you need more help PM me.
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Sep 2015
    10
    Here is another log after using the new map. Thanks.
    S3664.hpl
    2003 CHEVY TAHOE 2BAR-SD-NEW-FUEL.hpt
    TahoeTurbo.cfg
