Results 1 to 6 of 6
Thread: VVE Editor and Torque/Inverse Torque Calculation
    Mar 2010
    Texas Hill Country
    3,299
    After spending quite a few years tuning GM stuff, including my latest E92 blown/stroked C7 Vette, I am adding a 2016 GT to the mix....
    Are we going to get access to a VVE Editor like the GM cals have with HPT to correctly configure the Speed Density tables?
    Are we getting something to automatically calculate the torque tables as has been mentioned in the past?
    Where can I get the deep dive full immersion on these PCMs/TCMs? They are different enough, at least in name, that I want to make sure I know what I am looking at, outside of the obvious.
    Thanks!
    Nov 2009
    All Around
    3,149
    i believe eric is working on finalized a torque calculator that will be available in the scanner.
    almost no one actual does any changes to the SD tables, you will be tuning the maf.
    torque and inverse would need to be changed with forced induction is introduced.
    check out the latest HPT release from Don Lasota its a good start up read
    Mar 2010
    Texas Hill Country
    3,299
    so just absorb SD error into the MAF correction or put it in MAF only? can you even do that on these cars?
    Nov 2009
    All Around
    3,149
    dont worry about SD, just MAF it
    Jun 2008
    Tyler/Longview, TX area
    746
    SD is used only when you have a failed MAF.
    Mar 2010
    Texas Hill Country
    3,299
    So the Fords are MAF only during normal use? Not like the GM hybrid stuff....? I guess that should make tuning a lot quicker/easier.
