Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: hellcat wot afr
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    hellcat wot afr
    Just curious where everyone is seeing the afr at on these
    Yesterday's dyno session kinda opened my eyes on these things, afr is very lean, very similar to direct injected engines
    Car makes the most power and accepts timing best at 12.1-12.3
    at 11.9-12.1 it looses 25-30hp
    at 11.7-11.9 it looses an additional 30 hp and starts getting into kr, pulling timing to eliminate kr nets same hp.
    I also noticed that loosening the knock sensor settings to get an additional degree or more timing netted no hp gains.
    Basically dodge has done their homework on this.
    Just curious if anybody else is seeing these same afr's
    This was 15lb pulley
    14.5* total timing after all adders
    air raid cai
    50hp cheater shot
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Feb 2015
    25
    Quote Originally Posted by mbray01 View Post
    air raid cai
    50hp cheater shot
    Where are you reading the AFR? Where is your sensor located?
    AJ
    Dec 2013
    Slidell, La.
    1,015
    I had a wideband in tail which usually reads .3 leaner than when I install one at collector
    factory sensor reads .85 lambda, or 1bout 12.1 on e10 and read 12.4 at tail, so everything seems in line. It just loved it there
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    they run very lean from the factory. I'm tuning one now and actually find richening it up helps.
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Nov 2013
    23
    I'm also tuning on a hellcat. With a 3lb pulley, I'm making the most power around 11.6-8:1 A/F at ~16(still safe for pump) degree's timing. Once I go below 16 degree's timing, it'll lose a bunch of power if the fuel is too fat. With your cheater shot(not sure if it's wet or dry), you'll probably want to keep the timing down below 15.
    Dec 2013
    Slidell, La.
    1,015
    im at 15 total.
    at the track the other night it got 18 and loved it. but track temp was about 58*
    the 50 shot is wet.
    i think im gonna play with fuelling again. try a few other things
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Nov 2013
    23
    Cool, let me know how it goes. Are you using the recommended fuel jet or running a hair richer?
    Dec 2013
    Slidell, La.
    1,015
    well, I am jetted for 65psi, which would make it fat, with the ecm commanding up to 92 at wot. so we are letting the ecm pull the fuel on the spray, which it does quite well. on spray still hitting the 12.1-12.3.
    i am going to bring to track next week, and see what she likes fuel wise in real world environment. I will try for 11.9, then 11.7 and see where it goes
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Jun 2011
    Tucson, AZ
    295
    So making it a little richer helps or hurts. The OP states it looses a ton of power when making it richer. Then another states it helps.
    2016 Hellcat Challenger, automatic, black on black with brass monkey wheels
    10.13@ 140 DA 5000 feet
    2.75 pulley, tune, drag radials. 10 percent lower od crank pulley, 1050 ix. off road mid pipe. tune
    Feb 2016
    431
    Leaner and less timing is the go.
    Don't be scared, they only burn up if you have too much timing in them.
    Oct 2013
    Denham Springs, LA
    146
    Yea i'm doing a Hellcat and Scatpack right now, both bolt oncars, scat pack has a 125 shot on it, just.. amazing how lean they run from the factory, the scat pack was a complete opp, it ran rich as hell.
    Jun 2011
    Tucson, AZ
    295
    Quote Originally Posted by ddtech View Post
    I am hearing tunes from both angles on the hellcat. And I am not saying one is wrong or right. I appreciate all views. On the hellcat forum I am on the tuners state it was only lean to pass emissions. But adding around 5% fuel to it picked up 30 plus horsepower. It was also mentioned that the timing is pretty much maxed out. Maybe with the extra fuel 1 degree advance from factory.
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    Are you guys reading the spark plugs?
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Oct 2013
    Denham Springs, LA
    146
    I always read plugs..
    Being on E85 makes that super hard, so when someone's on E85, i relay heavier on AFR / Trap speeds.. a Dyno yes.. but overall a trap speed will tell the better story.
    Dec 2015
    Riyadh, Saudi Arabia
    71
    are you experience LTFT and STFT while WOT ?
    Jun 2011
    Tucson, AZ
    295
    I am using a diablo handheld tuner for the Hellcat. I still have hp tuners. I used that for my stroker G8. However I have no clue on tuning a Hellcat. But Diablo agrees with you. On their test cars without pulley additions they state from the factory it comes in the low 12s. 12.1-12.3. They stated adding fuel just slows it down. That this car likes to run lean to make the most power which is a little unusual. A few are saying that it is done for EPA reasons. But as far as I know EPA does not test at WOT. But I may be wrong on that. I think they loosened up the knock sensors a bit and maybe added a slight amount of timing on their 93 tunes. Not much. But you said that did not even do anything for the hellcat. So basically if you are near stock just stay with the stock tune. You can utilize the Diablo though to up the rev limiter 600, turn on the fans sooner, and play with the throttle booster. I hear if you up the rev limiter and put her in manual with the automatic she will shift at 6300 automatically without having to hit the paddle shifters. That is good since it is still building a little power up to 6300 rpm.
    Feb 2016
    431
    12 - 12.5 afr is not lean on these.
    Most run their stuff too rich...cos it is 'safer', cos if it fails the client can't say it was tuned too lean.
    That is old skool thinking...just trim fuel to where it makes power...that is where it likes it...as long as you don't have too much timing in it, it will go forever.
    The smaller and/or better the injectors are the leaner it will like to be.
    I've done some dual injector per cylinder stuff with newer super fine atomisation injectors and they like to run even leaner, use way less fuel and still make more power...go figure...
    If you run big, lazy, fire hose style injectors, it will appear to like more fuel and a richer afr.
    Jun 2011
    Tucson, AZ
    295
    the afr on the heads up display how accurate is it on the hellcat on wot? the guys on the hellcat forum state that if it reads 11.8 the true reading is about 12.1. They believe it reads .3 too rich.
    May 2016
    1,134
    Very possible people are comparing what their display reads vs a tailpipe sniffer on a dyno and assuming the dyno wideband is correct and the factory one is wrong.
    Jun 2011
    Tucson, AZ
    295
    I think you are right. The OP states at 12.1-12.3 the car made the most power. If the car still had cats it could of been around 11.8 which is where Dodge set these cars to be. I also saw some blogs stating these cars are run super lean. 12.7. Not! They were being read with a stoich of 14.7 when the car has a stoich set up by Dodge at 13.6 or 13.7. 14.7/13.7 is around 7 percent. 12.7/1.07 is 11.86. Amazingly that is what they are reading on the heads up display in the car.
