TL;DR? Unfortunately, I am not sure what Main Spark Advance "In Min", "Ex Min", "In Max" or "Ex Max" are, at a technical level. I've arbitrarily utilized "Intake Cam Des Angle" [PID.2170] and "Exhaust Cam Des Angle" [PID.2176] as int/ex vectors, and then I include samples based on less-than or greater-than midpoint (~25 on a scale of 0-50). I believe this to be inappropriate and I am seeking advice on more appropriate PIDs and/or value ranges.
After reviewing some videos and threads on KR calibration I decided to create new histograms which would, in theory, help me to perform a more accurate calibration relative to Min/Max Intake/Exhaust states.
Prescribed method I have seen thus far:
1. Go to Engine->Spark->Advance
2. Make a clipboard copy of "one of" the tables, such as "Intake Min, Exhaust Max"
3. Paste clipboard into all four tables.
4. Copy adjustments from "Total KR" table, such as "CSSOB's KR Histogram"
5. Apply adjustments to all four tables.
However, there are four different tables for a reason, and I suspect I may over/under compensate if I copy/paste the tables over one another, and or copy/paste a single KR vector over multiple tables.
Seeking a more pragmatic approach to adjusting these tables I've set out to create separate histograms to capture KR filtered by the 4 Min/Max states:
The filters for each are as follows:
KR MnMn: [PID.2170] < 25 AND [PID.2176] < 25
KR MnMx: [PID.2170] < 25 AND [PID.2176] > 25
KR MxMn: [PID.2170] > 25 AND [PID.2176] < 25
KR MxMx: [PID.2170] > 25 AND [PID.2176] > 25
I would *reallly* appreciate some feedback on values which may be more correct, or PIDs which are more appropriate for what I'm attempting to do.
Thanks!
