Just curious if anyone has spent any time dialing in the VCT angles with Comp's stage 3 NA cams. There's a lot less range to work in since you only get 20 degrees of sweep, but I was hoping someone's played with them some. Do they seem to want to be in the same range as stock cams for peak power, or do they like to be further off? Hoping for some good base settings to work from.
