I have experience tuning NA motors but not much tuning FI. The last car I tuned from scratch with FI was an LT1 with an FMU.
- Is pulling 1-2* of timing out per lb of boost still the rule of thumb? Should I just scale the main spark advance table by the same number except for the idle areas?
- Should my target AFR be in the 11.5-11.8 range? The car has headers with cats.
- Should the car need idle adjustments?
- Should I tune MAF-only or try use Bluecat's stuff for virtual VE as well? I haven't done VVE tuning yet.
I'm going to a 2bar MAP sensor, so I'll be upgrading the OS and also tweaking whatever I need to there. I hope I can search this forum for info on that. Any words of wisdom or links would also be appreciated.
This is for a C6 Z06 with ~6lbs of boost on stock shortblock with ID850s.
