It feels like the MAF is maxing out at the very top of 1st gear. As you can see I have no KR, and I also am locked in at 11.5:1 AFR
It's doing the usual shut the engine down, then it slowly comes back up to idle like a maxed out MAF behaves.
I brought the max HZ to 20K and shut off the p0103 High fail, but that had no effect. Do these pcms also look at max grams/sec? Can we even adjust that limit?
Here's the scan.lesabrecut.hpl
Setup: GenV, 3.5 pulley, l36 block, headers, 1.9 RR, Ported heads and LIM, 3" exhaust
