Cold air intake, long tubes, corsa exhaust. don't know all the cam specs, but about 620 lift both sides.
zero problems except for this surge. wanted to keep smoothing on but massage the tables all i want and not helping much. disable and a big help. but really touchy. so i put timing from 1-2000 to 30 degrees. better. now it's something you notice but could probably live with considering the limited range of it, but still, i don't think it should be there.
similar posts have also zeroed in on closed loop correction and this is choppy and when i just plain turn it off, it is a little better. this is a maf only tune and i don't know the brand of the cold air intake but it's not in the stock housing. i think i have the maf pretty well dialed though.
attached is a log with CL enabled (around frame 540 is where it goes steady throttle and the surging starts) and then later with CL off (around frame 1375). just watch for the "Advance" white line in 3rd one down of chart display to go ruler flat.
so here's what i'm seeing. you look at that advance and it's rock solid. look at etc and it's solid, look at the pedal and solid as well. trims are kinda jaggy though. you can feel the surges here. another try with CL off and it is better, those trims may have been problematic.
but then i look at the o2 sensor readings in the 4th chart display and i see how they have these same tiny dips in them, small but noticeable, just like the surging. what i'm wondering is if there's a mechanical problem. the sensors look like they're recording misfires. perhaps this is a mechanical issue then. stock injectors, stock TB and intake manifold though.
any help on this very much appreciated. would like there to be no surge.
