Results 1 to 5 of 5
Thread: Vats Passlock
    Apr 2010
    45
    Vats Passlock
    Buds 2001 Silverado is having Vats problems. Suspect wiring or key cyl. Tried the old resistor trick but can't get a steady Ohm reading to
    find out the value. So I was looking at the tune file and don't see a Vats patch in the OS tab but in the Sys-general tab I can select Serial-PWM or
    None. Is that all I need to do? Select None in that tab and do I need to write entire? Then no more trying to relearn the BCM- Key on- off-on, ARGH.
    THanks
    Dec 2012
    Somewhere in Mexico
    230
    Yup, just set it to none and write calibration only has worked everytime for me. If not try write entire.
    405
    2,315
    Depends on if it won't crank, or if it cranks, starts, then dies. If the latter then yes that is all you have to do.
    Apr 2010
    45
    Sweet! Yep it cranks and fires then dies. Security light comes on solid.
    Tuner in Training Jabercrombie's Avatar
    Dec 2018
    26
    Mine doing same thing but will not try to crank so what should I do ? I replaced the anti theft module after it was stolen and tried to relearn keys but no go.
