I searched but didnt get a definitive answer.
So how does the PCM decide what the "air fuel ratio commanded hi res(or low res)" is and where does it come from?
I ask because when first entering into PE mode, commanded AFR is where I sent the AFR in the PE EQ Ratio vs. RPM table ( 12.84 AFR) but as I increase in RPM's it goes richer and richer all the way to like 11.70??(commanded) and so my scanned AFR reading corresponds. Now yes I can change my PE EQ ratio to fudge it to a good WOT AFR (approx12.8-9) but again why is the PCM commanding something different? know what I mean?
Thank you!
Bryan
