I'm trying to get a handle on the MAF curve calibration.
I have attached two logs and tune files. One has the MAF aurflow vs period at stock levels and the other has it with 30% added. I also tried 30% subtracted. I can't get the ST fuel trims to change much, and after a while running they stop changing. Also both o2's are at .74-.76 but commanded around 1.0 not matter what I change I can't seem to get them to change.
they are both within .1-.2 of each other. I have LTFT disabled and MAF temp correction until I can get this somewhat close
Base file Turbo 80 goes with first2 log
Base file Turbo 80 with 30% out goes with 30%out log
I have tried very drastic changes t the period table with very little results
I'm just needing a little help getting on the right track
