witch tables would i use to tune off my na tune for nitrous
looking to start ajusting my na tune for my nitrous, i know i need to pull timing per 50hp ,and i also have a stand anole fuel cell .i know the timing table .just wondering what other tables is their that i might need to ajust or check
curtisb, post up your tune mate....Pull 2* every 50hp shot and go from there....Is it a WET shot ? or DRY ?...If wet do fuel adjustments with the Fuel Jets to get the Lambda spot-on and check plugs....When you are rich or lean on NOS it will backfire....So get your Timing spot-on and your jetting if Wet shot.....Cheers Bret@ultimatelsxtuning
