Results 1 to 4 of 4
Thread: back fires but no start!
    trying to get the car to start and run. when cranking it will pop and backfire but will not start and run. i have exhausted my limited knowledge of what could be wrong. if someone could take a look at how things are and possibly point me in the right direction i would greatly appreciate it.
    setup:
    97 trans am
    ls7
    e38 computer
    id1000
    zr1 map
    granitelli maf
    it is on 93 oct.
    start attempt.hpllt427.hpt
    Nov 2009
    All Around
    3,149
    something is not in-sync, cam sensor/crank sensor
    Tuning Addict
    Jan 2015
    6,813
    Can't see the tune, but how did you scale for the injectors. Data fit completely or max out somewhere?
    ~Greg Huggins~
    Dec 2006
    Rockwall, Tx
    247
    Quote Originally Posted by supercamaro427tt View Post
    setup:
    97 trans am
    ls7
    e38 computer
    id1000
    zr1 map
    granitelli maf
    it is on 93 oct.
    Double check the coil harness and make sure the harness is plugged into the correct cylinders. It is possible to plug them in backwards and have the symptom you are experiencing.
