Results 1 to 7 of 7
Thread: Can someone take a look at my VE tuning file? Modifiers I'm not aware of?
    I keep VE tuning my ride and not getting great results. Can someone take a peek at my VE tuning file to see if there's something I'm missing that is modifying the fueling that I don't know about?
    2009 CTS-V Modified (VE Tuning)3.hpt
    TIA!
    Chris
    Anyone please take a peek please? I want to get out and do some tuning tomorrow.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Define "not great results"
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    I can't get closed loop with dynamic airflow blending to return LTFT less than 20%. I was seeing less than 3% error on my open loop VE and MAF but when I put them together and enabled closed loop. Ran for 20 mins, reset the trims, and the lambda was straying a long way from commanded 1.0 lambda.
    It was suggested that I start again from scratch so I figured that I would get back to square 1 and make sure my tunes for VE and MAF tuning were correct. Here's my MAF tuning program.
    2009 CTS-V Modified No Cats, ID850's, PE Edited, Delete TM, Fans (MAF Tuning)3.hpt
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    How does it do in MAF only or VE only and closed loop? I know MAF+VE+closed loop you're having problems but wasn't sure about MAF or VE individually when in closed loop
    Can you disconnect your EVAP solenoid wiring and zero out the "reduction factor" under LTFT purge cells? As a test at least..
    And.. any logs?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    And.. any logs?
    I guess I'll have to try MAF and VE only in closed loop.
    I haven't tried unplugging the EVAP yet either. What table is the reduction factor in?
    I have a ton of logs. I think I'll try MAF and VE only in closed loop to see what happens first.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by wetcoast View Post
    It's somewhere under open/closed loop in fueling I think.. you'll see it
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
