Results 1 to 11 of 11
Thread: Injectors
    Injectors
    Little help on injectors. 15 gt, got 09 gt500 injectors (47#) and need some help on what to change to make it work. Thanks
    Jun 2008
    Tyler/Longview, TX area
    746
    Copy everything from the Roush tune in Fuel>General>Injector Control>Flow Rate.
    Aug 2014
    27
    Not the same injector as OEM Roush. Calibration data for what you have is here: https://fordperformanceracingparts.c...-9593-g302.pdf
    Jun 2008
    746
    Quote Originally Posted by kdanner View Post
    They are 47lb FRPP injectors. I know because I replaced them with Id1000s. Your link shows data for 39lb fuel pressure. 15 Coyote uses 58lb pressure.
    Aug 2014
    27
    Quote Originally Posted by txcharlie View Post
    Yes, 47# but coyotes are the LU47 injector, not the G302. You'd use the multipliers in that sheet to get the calibration correct, for example AHISL*FNPW_HSCOMP
    Jun 2008
    746
    You are correct. GT500 uses a shorter 47lb injector and the data is different.
    Will the shorter injector still fit?
    Aug 2014
    27
    They are about 12MM shorter. I don't know what kind of intake manifold, rails, etc, you have. If it is for the stock coyote length injectors, you'd need some of the spacer kits available in the aftermarket. I'd rather use the longer injectors if that is what your particular hardware is made for though.
    Its all the stock 15 stuff.
    Feb 2011
    Long Island
    129
    Quote Originally Posted by 02GTP View Post
    Why change injectors if its all stock?
    Apr 2015
    CO
    99
    Quote Originally Posted by realspeeddan View Post
    I would 02GTP wants to run E85.
