Results 1 to 3 of 3
Thread: Breach Birth
    Tuner seven ends's Avatar
    May 2007
    Houston, Tx
    155
    Breach Birth
    Just sharing. After inspecting and torqueing everything else, and thinking how stupid it is to do it but feeling a little desperate I looked up the tailpipe. What a way to spend a Saturday. It broke the rear O2 on the way out as well. Truck ran fine like this out of boost; boost a different story. Lack of power, stumble, and sounded like the blower had a hole in it. But I am happy because of all the other things I thought of that it turned out not to be.
    2010 Avalanche 4WD; AES 390; Mast LS3 heads; VVT Cam; ported TVS2300; Overdrive 8 rib pulleys; 2.7 snout pulley; ID1000; LS3 TB; WB 450; Twin MM cans; built 6L80; CircleD Triple Disk, CSR flexplate; Trucool 40K; Aeroforce Dual; AFX
    13,565
    You don't need a cat anyway.
    Not to be a hole but that is awesome.
    Dude you made so much power you blew out the cat
