Hey guys, finally got my F-150 on the Dyno tonight. Truck drives great, but as soon as you get into boost it pretty much falls on it's face. Makes about the same or less power then a stock F-150. I have the tune included, i'm guessing that i'm over looking something. What would cause it to just go nowhere!? It doesn't seem mechanical since it honestly drives so good out of boost just makes no power.
2006 F-150, Vortch S-trim, GT500 60lb/hr Injectors, 0 heat rang plugs (Stock were 2). 5,4L 3V motor all stock internally.
Dyno Info.
~15psi
SAE Timing said 14deg
AFR's were 10.8-11.3 through the pulls
93 pump gas
IAT's were 190def F (I know they are up there)
Throttle angle said 82deg through the pulls
Anything stand out as to why it would be down so much power? It didn't ping etc either, starts and drives great otherwise. Just stumped....
Thoughts?
8-29-15 Dyno.hpt
