So I have a LC-1 with blue digital gauge.
Recently got the tuning school cd about setting up wideband and voltage offset. In the dvd they are using an LM1. I'm just curious if when changing the voltage offset through LM programmer will the gauge read off since its just looking for a 0-5 volts and reprogramming it shifts the voltage curve?
Basically asking if I change the default analog outputs on the same signal to the gauge will it not read correct cause the gauge is looking for that default analog signal?
The analog outputs can be programmed, see chapter titled ?Programming the Analog Outputs?. The default analog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39 AFR. The analog outputs can be programmed with the provided software
