you always have to have some sort of ve for maf use to reference off of because the maf only gives you a reading in flow...there is no density value to the maf.
"Dynamic Airflow High RPM Disable: Above this RPM use filtered MAF airmass for airmass prediction calculations." -- it uses it as an addition too. know where does it say it disables base running airflow to run maf.
does the ve have a lot of say in this mode...no, not really. the maf is the main variable, but it still needs to reference the other sensors to be able to tie a density to the maf's airflow output.
