Originally Posted by
patooyee
I'm gathering info about the various part numbers. This is just as much for my own future reference as it is for general info. Here is what I've found so far:
-GM 12592016 = ACD 213-3843 = Airtex Wells 5S8027
*2.5-bar - unconfirmed other than internet lore
*Used on 07+ LNF engines
*MAP only, 3-pins
*Pigtail???
-GM 12592017 = ACD 213-3847 = Airtex Wells 5S8059
*ALSO used on LNF turbo engines
*TMAP, 4-pins
*Pigtail???
^^^I think LNF's used both of these for some reason. One for temp, the other for MAP, even though one of them does both? If you try to look up the second on on any parts resource it doesn't pull up under MAP, it pulls up under IAT. The reverse is true of the first one.
-GM 90423637 = ACD 213-3907 = Airtex Wells 5S6754
*used on LSJ engines
*TMAP, 4-pins
*pigtail GM#88988320, ACD#PT1863, pigtail is more expensive than the sensor itself! I think this might also fit the above 4-pin sensor?
