Turbo Parts
12652494 - K04 Turbocharger $1,365.11
12609878 - Turbocharger to Catalytic Converter Gasket $17.37
12618586 - Turbocharger to Manifold Gasket $13.82
12589452 - Support Brace $20.82
12589408 - Heat Shield Turbo $32.58
12654315 - Oil Pipe Feed Line $100.56
11561946 - Bolt for Oil Line (2) $22.71 each
12611119 - Gasket for Oil Line (2) $7.40 each
12626611 - Water Feed Line $111.58
12618973 - Water Return Line $97.82
11561875 - Bolt for Water lines (3) $15.85 each
12626102 - Gasket for Water lines (3) $9.26 each
12602397 - Exhaust Manifold $482.74
12622668 - Manifold Gasket $11.30
12612286 - Heat Shield Manifold $35.55
12609268 - Catalytic Converter $877.57
15709703 - Nut for Cat to Turbo (4) $2.25 each
Oil Return Line - $89.99 (I have priced these out from ZZP but waiting on a quote from DDM.)
Total for Turbo Parts: $3,301.36
Water System Parts
12605853 - Thermostat Housing $128.51
90537471 - Thermostat Housing Gasket $23.28
12592401 - Outlet Pipe $49.58
90537379 - Outlet Pipe Seal (2) $15.17
Audi PN N90692901 - Audi A4 B8 2.0L Turbo Coolant T-fitting $12.00 at O'Riely*
1" to 3/4" barbed hose adaptor - $5.40 from Napa*
1' section of 7/8" coolant line - $4.40 on eBay*
3/4" to 3/8" barbed hose adaptor - apx $5.00 from Napa*
1' section of 3/4" coolant line - $3.52 on eBay*
Various size hose clamps (5) - apx $4.00*
*These parts are all to tie in the Water Feed line into the upper radiator hose. I found a couple 1? to ?? adaptors but I don?t believe they are rated for engine coolant. Still looking for a better solution than this daisy chain of reducers.
Total for Water System Parts: $254.86
Intercooler Parts
25820725 - Intercooler $542.37
10386886 - Mount Bracket, Left $55.53
10386887 - Mount Bracket, Right $55.53
11609681 - Mount Bracket Bolt (2) $3.26 each
11589039 - Mount Bracket Bolt (4) $3.30 each
19129912 - Mount Bracket Insulator (2) $12.58 each
12595594 - Pipe Assembly $49.82
12615136 - 2 Bar MAP sensor $100.98
19129916 - Inlet Hose $123.86*
15286316 - Inlet Hose Clamp $9.88*
19129914 - Inlet Pipe (IC Hot pipe) $280.05*
20813754 - Upper Bracket $14.47*
15238800 - Lower Bracket $56.88*
15937524 - Air Baffle $30.15**
25791143 - Support Brace Right $23.33**
25791142 - Support Brace Left $23.33**
*These parts are optional if you decide to go with a different solution for your Intercooler piping on the hot side like I did by building the piping using eBay components. However, these stock pieces will work on this build.
**The 2.0L Turbo Sky uses a different Air Baffle and supports in the front bumper to direct air properly towards the Intercooler and radiator. Hardware from the parts on the 2.4 can be reused to attach these new pieces to the body.
Total for Intercooler Parts: $1,411.06
Fuel System Parts
60# Fuel injectors (4) ? $159.00 (I have priced these out from ZZP but waiting on a quote from DDM.)
Total for Fuel System Parts: $159.00
Unique parts that must be fabricated or modified
Universal 2.5? intercooler 8 pc Piping Kit Aluminum - $90.00 on eBay. You need to make sure the kit you get includes piping with 90 degree, 45 degree, and 75 degree elbows. This kit has pipes that are all 18" long, couplers, and t-clamps. This kit is used to build the cold pipe coming off the intercooler. I will be using it for that and the hot side so both sides match. May need more sections of pipe or to cut and weld some of this pipe for final fitment. I will also be using some of this for the new intake. Note the cost on this may increase as the build progresses.
2.5" OD Slot Style MAF sensor aluminum bung - $23.95 on eBay. This will be welded into the cold pipe coming off the intercooler.
JDM Universal manual boost controller - $12.45 on eBay. Used for controlling the boost pressure of the K04 turbo. Still need to check other boost controller options at this point. Not sold on this one yet.
Aluminum 1/2" hose nipple - $14.95 off eBay. This is to connect the vent line from the head of the 2.4 to the new intake tube. This will be welded on the intake tube.
Tune - Free to $600. Really depends on what you have and what you want to do. I have talked to DDM about this and they said they can sell me the tune for this but still need to work out details. If you already own HPTuners, this is basically free but if not then it will all depend on the options you choose.
Total for Unique Parts: $141.35 - $741.35
Total Build Cost (MSRP):
$5,267.63 - $5,867.63
