Results 1 to 11 of 11
Thread: Ve table or maf
    Aug 2015
    33
    Ve table or maf
    Should i tune just the ve table and leave the maf tuned out
    13,564
    I would always use the MAF sensor if you are not going to be going speed density with like a turbo setup.
    Tune both if staying NA.
    Aug 2015
    33
    I do plan on going boost ive herd a lot of people duing away with them just becouse of haveing problems with them
    Aug 2015
    33
    right now im just trying to tune with the cam set up but im bulding the turbo setup on a outher motor right now and plan to turbo at the first of the year
    Dec 2012
    Somewhere in Mexico
    230
    What 5FDP said. VE and maf if staying n/a. You will have to upgrade to 2bar or 3bar O/S if going boost so you cant use maf.
    Aug 2015
    33
    should I do the maf set up first
    Jan 2008
    242
    Yes if installing cam only just tune the MAF.
    Aug 2012
    SV, AZ
    447
    Quote Originally Posted by askkmb View Post
    That's not accurate.
    Aug 2015
    33
    I dont under stand be couse if it had a turbo it would only be going in to boost under med to full throttle just cruseing and normal driveing it would not be going in to boost
    Dec 2012
    Somewhere in Mexico
    230
    Quote Originally Posted by Eaglegoat View Post
    Whats not accurate about it? If going boost the maf will max out so SD is the way to go.
    JOHNB - To accurately tune fueling you will need a ve table that reaches further(2 bar or 3 bar O/S) than the stock one does. Unless you run really low boost.
    Aug 2012
    SV, AZ
    447
    You can use a MAF with the 2/3 bar operating systems. If you run into limits there are several ways you can overcome them. It's called scaling. You don't have to junk your MAF if you don't want to.
