Banned
SD tune - ignition map
Hi,
First of all i have tried to search but failed to find answer about this.
VE table is scaled with parameters of MAP and RPM reading.
Ignition table is RPM and Cylinder Airmass (g/cyl)
Question is if there is an option to switch from Cylinder Airmass to MAP in ignition table ?
Best regards
WASyL
I dont think it is possible but maybe someone else can confirm. But why would you want to change that? The scanner also reads g/cyl in the spark tables.
Banned
well maybe, but when i do RTT (even with MAF plugged) in Folloe Vehicle mode, it only moves in bottom row (1.80 g/cyl) but correct RPM reading, any idea how to fix it?
best regards
Banned
