STFT Maf Correction
So it looks like the new scanner you can open other peoples graphs now. I believe I made a graph for stft vs maf period and want to share and see if others want to test it and see how it works. I made it with bank 1 and bank 2 and then one called stft which is a average of both of them. I did change the maf periods in the graph to match what periods I'm using in my tune.
https://www.dropbox.com/s/k5h8n1pbsh...raphs.xml?dl=0
So I broke the first graph I uploaded stft's in the graph was not set to %. What is everyone setting the polling interval rate on there maf period? I got my car running and did a log but I don't think I have the polling rate set right because it didn't pick up much correction. I changed the link in the first post to my new graph.
Is this in 2.25? Happy to try this out!
Ya 2.25 if you have the latest beta scanner you can go to graphs and open other peoples graphs.
So the Row displays percent error from the STFT?
There is LTFT STFT1 and STFT2. The STFT at the bottom is the average for STFT1 and 2. The LTFT is not setup to do the percent error but I might do that.
