Originally Posted by
cobaltssoverbooster
What kind of tune file are you looking to make? Drag, Auto X, Large Circuit, DD Sleeper?
As for your file:
You still have tables that are set to multiple condition mode and you need to get those set into default commanded mode so you can have proper control.
I suggest going to the lnf bible thread (link in my signature section) and reviewing the lnf videos. You have a lot of features that need to be defaulted, raised, lowered etc.
Your misfire like symptoms:
E47 isn't known for capping out fuel injectors like E60 and E85 are. Chances are you blew the injector seals out (very common) or have old spark plugs that are struggling to be consistent under the higher load you now command. If your popping noise sounds like popcorn exploding in a pot then i would bet you lost at least one injector seal. For now lets wait to see your log before you go tearing everything apart for physical inspection.
