Results 1 to 18 of 18
Thread: Random timing dip causes bucking
    Aug 2013
    Jacksonville, FL
    7
    My car bucks a little when driving mostly steady state. It correlates to when the log shows a sharp dip in timing. The timing dip does not happen when I'm WOT. The timing dip is not associated to any particular change in throttle and no knock is recorded. My car is a 2009 CTS V with 592whp.
    Here is the mod list:
    • ID 1000cc Injectors
    • 2.4 Pulley
    • Cat Delete
    • LS7 throttle body
    • Track Attach HX
    • Varimax Intercooler Pump
    • Norcal intercooler tank
    • Dual NGK AFX widebands
    • Airaid Intake
    • Dual SMC catch cans
    • Relatively new cooler spark plugs
    I realize that most of those mods don't directly affect the directly engine, but I want to share the non-factory stuff just in case.
    Timing Dips.hpl
    CTS V Tune - HP Tuner Help.hpt
    Thanks in advance for your help.
    Aug 2013
    Jacksonville, FL
    7
    The timing dips are located at:
    • 1:02
    • 1:22
    • 1:41
    • 2:22
    • 2:49
    • 3:10
    • 3:40
    • 4:22
    • 5:06
    • 5:54
    • 6:15
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Zero your A/C Torque Reduction table if the timing dips occur when the A/C is on.
    Russ Kemp
    Aug 2011
    Alaska
    566
    Does that car have a manual? If so, disabling spark smoothing cured that in my car.
    When arguing with an idiot, make sure he isn't doing the same thing....
    Aug 2013
    Jacksonville, FL
    7
    My car is a manual. I'll try both suggestions this weekend. Thanks
    Tuner openwheel25's Avatar
    Jun 2011
    Lawrenceburg Indiana
    94
    How did the suggestions work? I have the same problem. What I have found is that it is torque management advance. That is what comes up on the scanner when it does it. I have disabled all of the torque management but it didn't help.
    Sep 2008
    1,668
    It actually looks like at 1:22 it's switching from the high octane table to the low octane table, then switching right back...but the other instances don't appear to be doing that.
    There are a LOT of spark retard PID's you can log that may help identify it.
    I don't advocate leaving the tune this way, but have you tried copying the high octane table to the low octane table to see if it changes the problem?
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    def ditch spark smoothing, I freaking Hate it.
    also, burst KR will cause massive unexplainable timing dips.
    Aug 2013
    Jacksonville, FL
    7
    The car does it when the AC is off and spark smoothing is disabled in the tune. I'll try logging some knock PIDs, but the log doesn't show any knock correction.
    Jan 2008
    242
    Return to stock Injector Flow Rate Modifier vs IAT and Tip-In Limiting ETC Limit. Also Fast Torque Exit back to stock.
    Aug 2013
    Jacksonville, FL
    7
    I've set low octane timing to the high octane timing. I tried disabling the ignition control on the traction control settings. None of the those settings has helped. I logged knock burst and it's not happening.
    Quote Originally Posted by C5 2000 View Post
    I'll try this next.
    Jun 2011
    94
    Your scan looks just like what is happening to me. Next time also try to log Torque management advance. I know the timing is retarded, But when the timing is being pulled on my car the only thing that the scanner shows is torque management advance. It can't hurt to log it too.
    Aug 2013
    Jacksonville, FL
    7
    Quote Originally Posted by openwheel25 View Post
    I logged the Torque management advance and it showed up when the timing dip occurred, but only at the point bottom of the dip and on the way back up to normal timing. It seems that the ECU used it to smooth the transition back after the large drop.
    I decided to use the process of elimination to debug the situation. I took my stock tune and only moved over the most required settings like MAF, high octane ignition timing and injector settings. The timing dip was gone. I slowly added settings back until the timing dip returned. The culprit was that the Supercharger Torque settings of Spark, Fuel Cut and ETC were disabled. I didn't test them individually, but having them all enabled like the stock tune cured my issue.
    Thanks everyone for your help.
    Jun 2011
    94
    Thank you very much for keeping all of us informed. I have a question. Do you have supercharger fitted in your tune? I am not sure how I have my supercharger torque settings set but, I am sure I have it set as supercharger not fitted. I would think if it was set as not fitted any setting for it would be ignored. But, I can't wait to check how it is in my tune and try it. Thanks again for your feed back.
    Tuner seven ends's Avatar
    May 2007
    Houston, Tx
    155
    That was my question in post #58 of below thread 3 weeks ago. Would be nice to know more about this tab in general for vehicles not originally fitted with S/C.
    http://www.hptuners.com/forum/showth...U-really/page3
    2010 Avalanche 4WD; AES 390; Mast LS3 heads; VVT Cam; ported TVS2300; Overdrive 8 rib pulleys; 2.7 snout pulley; ID1000; LS3 TB; WB 450; Twin MM cans; built 6L80; CircleD Triple Disk, CSR flexplate; Trucool 40K; Aeroforce Dual; AFX
    Aug 2013
    Jacksonville, FL
    7
    Yes, my tune has the supercharger set as fitted from the factory. CTS-V generation 2 and the upcoming 3 are supercharged from the factory.
    Sep 2010
    east central Iowa
    112
    My camaro is having the same issue, and am wondering if you've found the issue? Seems to be steady state driving, almost always when cresting a hill or on flat roads. Any chance it could be something to do with DFCO spark?
    I have a Cammed (comp 277Llr) and KB 2.8 s/c.
