got a 01 z28. recently installed the NGK AFX powerdex into the passenger B1S1 and tuned for OL in the pcm as well as hooked up the analog into the hp tuner (got the pro version). at idle and cruise the gauge fluctuates as normal but once i get into PE/WOT the gauge goes and pegs at 16.00 (thats the max value for the afx) however the datalog seems to read lower since im using the pre-loaded ngk afx Aux input List. i replaced the sensor thinking it was a bad one but still the same issue. is it something in my PCM or the afx thats the issue? i attached a copy of my .hpt in case i may have missing something tuning for OL. any help and advise is greatly appreciated. als attached a couple of my log scans.
