Originally Posted by
InsanePerformance
Hoping someone here can help me out,
I have converted an L98 and 6L80E into an R33 Skyline,
Everything is running well apart from 2 issues.
1: I have no Vehicle speed in the scanner, I can check with snap on scan tool and read a vehicle speed in the transmission but not the ecu side.
It has a bcm, pcm and tcm from 09 model vehicle. I read on the efilive forum that some os's may work and some may not. It also states that around the same time the vehicle speed is sent via can to the abs not the ecu. If this is the case can I
A: wire PIN 15 in the 6L80E to PIN 71 in the ecu connector and configure settings to receive the vehicle speed?
B: write a compatible os over my existing os that will work?
2: I have a 12v 1400cfm fan which is not pwm, does anyone know how I can make it switch on with the required temperature settings in fans or what settings will work?
OS 12633016 ECU
OS 24249179 TCM
