Results 1 to 15 of 15
Thread: not seeing close loop while regular driving
    Dec 2013
    28
    hows it going guys so i just put my motor back in my car and she wont go into close loop unless I start driving her aggressive and no matter how much fuel i take out or even put in she automatically just goes rich while driving at a cruising speed unless i blurp the throttle a little but then she goes back rich again. car is a 02 Trans-AM stock ls1 bottom end, JFR custom blower cam, untouched 243 heads and stock ls6 intake. I havent installed the procharger yet because of this issue. Its a 2bar SD tune with the 12615136 sensor but with the key on engine off shes showing 0 on the log and my 02 sensors and floating around the 447 area does anyone have any idea what it can be?
    Dec 2013
    28
    Iv checked all grounds about 5 times iv replaced the 02sensors and ive even checked the voltage to the 02 sensors everything checks out can anyone give me any info on what to check next?
    405
    2,324
    What do the O2 sensors do if you force closed with the scanner bi directional controls?
    Dec 2013
    28
    They do nothing at all even if i command 16.0 at idle in the scanner it just stays at 13.4
    405
    2,324
    Add Fuel System Status to your table display.
    Dec 2013
    28
    The log where close loop stayed on it said not ready until i started driving aggressively. its almost as if a wire is loose but i cant find it im going crazy over here
    Dec 2013
    28
    heres the config
    I got a similar same problem. What brand O2's are you using?
    Dec 2013
    28
    Im using the densos what about you?
    405
    2,324
    Describe the exhaust system and O2 sensor location. Using extensions, cut/spliced wires, or Vette rear O2s?
    Quote Originally Posted by 2xLS1 View Post
    Our car is a 2000 WS6 LS1 with 1 3/4 headers with ebay O2 extension harness. TSP true dual offroad.
    Dec 2013
    28
    02 extensions tsp 1 7/8 headers to tsp ory and slp catback
    Dec 2013
    28
    Can anyone tell me if there is a main ground to the o2 sensors? Also can someone explain as to why no matter how much fuel i add or remove she still wants to be around 13.4?
    405
    2,324
