At the risk of sounding completely ignorant, I'm having issues.
Vehicle: 99 Denali L31 5.7/4L60E
Engine has been built starting with 350 4-bolt. Forged steel crank, H-beam rods, 9.5:1, Edelbrock 170 E-tech heads, 1.5 rockers, marine intake, 36lb EV1 injectors, LT4 Hot Cam, still have 4X reluctor with distributor, ported TB, CAI, 2.5 dual into single 3, high flow cats, 0411 swap and wideband.
I have 01 Express base tune installed, put in SD mode by MAF freq fail high set to 0 and DTC's 101-102-103 set to first error
Vehicle starts and runs but I cannot get any VE data. It's idling low at 450-500 RPM although I have idle set at 800? I'm seeing a lot of timing 30*. idling pretty rough.
My wideband is an Innovate Motorsports MTX-L. Any links on how to wire into interface module?
And any idea why I don't see any VE data?
Any and all help is greatly appreciated. If I can get wideband wired in and make VE adjustments I should be able to get this thing to run a little better.
