Looking for some potential input on Tip-In hesitation.
It doesn't seem to matter what RPM or gear (even at idle); I get a pause/hesitation at tip-in.
It is barely noticeable when cold; however, most likely that is simply from being open loop.
It is less prominent with the Traction Control off
I have attached my tune, a jpg snap shot for an example and a recent 20+ minute log if that helps.
My wide band crapped out but maybe someone knows right where to point me.
This isn't a new thing, it has been there for since the 2012 Magnacharger, Cam install, and I have even recently upgraded the throttle body...no change.
My last dyno was at 521rwhp - 514ftlb - 5864rpm - 129mph - at 7.12lb of boost and I am not wanting to push it any more, just trying to figure out the hesitation issue.
If you see something or have an idea, please keep in mind, I am barely even classified as a rookie with HPT; I bought it initially for minor changes within idle, fan, gear, tire size, etc...but I am learning as I go.
7-12-15 SC-SSR tune.hpt Log Sample.JPG 7-13-15.hpl
David
