hi
I finished tuning VE table at WOT with the commanded AFR set to 12.7 and actual AFR is between 12.6 ~ 12.7 . Now the problem is when I command 10.8 AFR and retard a few degree for Dry nitrous shot . The actual AFR become in the 9 range ( nitrous off ) , this does not make any sense , this problem didn't happen before, the only change is software update. and am sure the commanded AFR was 10.8 I saw it in the scanner.
The car is C5 Z06 2003
