Results 1 to 12 of 12
Thread: Did I really get a NTK WBO2 Sensor from Autozone? (AFX NGK)
    Apr 2004
    Erie, PA
    464
    Exclamation Did I really get a NTK WBO2 Sensor from Autozone? (AFX NGK)
    Hi guys,
    I bought my AFX NGK WB unit around year 2009. Overall it has worked great but lately it has been acting weird at times so it was time to buy a new WB O2 Sensor again. After doing some searching on here, it seems the NTK is the better sensor over the "stock" one. I ordered one from Autozone for $69.00 this week and this is what I got (see attachments). The numbers on the box match what a NTK should be but the end of the sensor looks different and doesn't have "NTK" stamped anywhere on it.
    Is this a real NTK sensor or something else? Anyone else buy on from Autozone?
    Bill
    2001 Camaro SS M6 - 23,xxx Miles
    Huron Speed AC Turbo AC Kit - 6.0L 9.4CR, LS3 Heads, 226 232 115 lsa cam, Turbonetics 7575 1.15 AR Turbo
    10.98 @ 133 MPH on 9 lbs boost
    Aug 2012
    SV, AZ
    447
    Doesn't look like it. I had the same thing happen to me thru autozone.
    Mar 2010
    Texas Hill Country
    3,299
    why would you buy anything from autozone besides tire foam?
    Jan 2006
    Collinsville IL
    697
    I get the NGK/NTK 24302.
    https://www.facebook.com/tuningbyshanehinds
    [email protected]
    2009 G8 GT [email protected] 1.60 - Sold
    2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
    2013 CTSV wagon 9.21@151
    2015 C7Z bolt ons 10.0
    Apr 2004
    Erie, PA
    464
    Question
    Quote Originally Posted by Higgs Boson View Post
    Where do you suggest I buy that sensor from?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Ballenger Motorsports.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Apr 2004
    Erie, PA
    464
    Question
    DSteck, Did something change in the past few years for the NTK Sensor? Check out this thread: http://www.hptuners.com/forum/showth...-mnitor-sensor
    Found this on Ebay: http://www.ebay.com/itm/BRAND-NEW-OE...192eb7&vxp=mtr
    Found this on Amazon: http://www.amazon.com/NGK-24302-Oxyg.../dp/B001PNAPF6
    ...and another....... http://www.oxygensensor.net/ntk_o2/24302.php
    Aug 2012
    SV, AZ
    447
    Quote Originally Posted by 04blackgmc View Post
    What's the advantage over the bosch 15401?
    Dec 2008
    on the Dyno
    1,825
    They changed the sensor design about a year ago. I order mine online now to make sure I get the correct one. All of the new "cheaper" NTK sensors look like that now. Even the new sensor that comes with the new NGK wideband looks like the one you have pictured. I've used them without issues but prefer to use the tried and true design of the more expensive sensors they offer. There are 3-4 different grade NTK sensors that you can get and use with the NGK AFX or AFM1600.
    Located in Central Kentucky
    ShorTuning
    Tuner in Training bmotorsports's Avatar
    Mar 2008
    Richmond, VA
    34
    Quote Originally Posted by Billiumss View Post
    Hi guys,
    Bill
    Quote Originally Posted by LSxpwrdZ View Post
    Just to add to this, the sensor Bill found is a newer and lower cost sensor. Its primary purpose is a cost reduction compared to the traditional NTK sensors and we generally expect it to behave more like a Bosch sensor in use due to the way it is manufactured. We don't recommend this sensor with the AFX / AFR500.
    For the AFX / AFR500 we have a listing of all the accessory and replacement parts, including the sensor options here:
    http://www.bmotorsports.com/shop/pro...oducts_id/2337
    Sep 2008
    1,668
    I usually get wiper blades there...
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    I've never had an issue with their brake cleaner...
