Originally Posted by
mowton
OK, here goes...Cam isnt too bad (-4 degrees overlap) so lets set idle rpm to 800 (550-590 is too low), Add 1 g/sec to the Base Running AF table and 2 degrees to the stock idle timing.
Put Friction Airflow decay back to stock, (decay has been increased so it has less time to help) and set Friction Airflow Delay to like 25 cam rev's...more time to help before it gets decayed.
Put all the Adaptive Idle Airflow tables back to stock. When we get the idle desired air correct, you won't need that much padding...
Along the stock lines, put the Throttle Cracker enable/disable sspeed and airflow back to stock as well. Do the same for the Cracker.
I am assuming you have installed a stock TB/IAC assembly so put the IAC Steps table back to stock. The steps start at 12 mm2 which is what the throttle opening cresent s/b yield at closed throttle, then the iac steps impart their additional air. While not related, but just to keep everything inline, put the ETC scalar back to .0255 as well.
Now we are going to set up the scanner. Develop a .cfg that utilizes the following PIDS: IAC desired, IAC pos, LTIT PN/AcOff, LTIT Gear/AcOff, Idle Adapt (STIT), Idle Desired Airflow, Idle startup, Commanded AFR, RPM, ECT, MAP, Advance, Throttle Position %, Throttle position (V) and Dynamic Air.
First order of business is to get her started and dial in the IAC. If you haven't already, remove the setscrew from the bottom of the TB and re-install from the top...this will allow easy access for later adjustments. With the .cfg above, and at operating temp, adjust the setscrew so the IAC desired is between 50 and 80 steps and TPS volys is <.8v. Whne complete, turn engine off, unplug TPS and IAC. turn key on (don't start) for 20 seconds, shut off and reconnect connectors. This will complete the relearn process for the pcm and set 0% TPS as closed throttle. Let engine cool down and repeat if needed.
The last step is to log the LT and STIT from a cold start to high temp and update the BRAF based on these results. It is better known as the RussK cfg...
You do want to make sure that before you start tuning the idle/startup, that the VE and MAF are dialed in pretty good. with no drive shaft, suggest you duial them in down from 1200 rpm to say 800 by using the VCM Controls.
I know this is alot, but the Gen III's take a bit more effort then their offspring (E38/E67) :-)
Ed M
