I'm currently using a stock F150 Coyote/ECU, and want to convert to running a static fuel pressure like the FRPP Coyote Power Pack does. The instructions in the power pack, say to supply 55 psi constant to the fuel rail and use a vacuum referenced regulator.
I plan on using a Corvette fuel filter/regular assembly which produces 55-58 psi regulated, however no vacuum reference. My question, is in the tune, as you can see on the Ford Racing computer, the values are set to 55 psi:
And here is my stock tune, which appears to have a slight variance in pressure:
I'm assuming this is the proper area to be changing to run a static pressure? I'm using the stock injectors, and the motor is entirely stock.
