Needing Bosch 0280158827 160# injector data
Anyone have data for the Bosch 160# injectors, part: 0280158827?
Already searched all over here and ls1tech with no luck.
Car is 2001 Camaro with factory PCM, reflashed for 3 BAR SD.
-408 LQ9
-Boost referenced fpr starting with 43.5# base but can lower if need to all the way to 30#.
Looking for this info if possible:
-Offset vs. volts vs. VAC
-Short pulse limit
-Short pulse Adder
-Minimum Injector Pulse
-Default Injector Pulse
Thanks in advance!
