2007 Mustang 3V, 2.8 Kenne Bell with dual 75mm throttle body. Car ran fine prior to scanning and re-flashed the tune (no changes made to the tune). The car will start but dies with P2104 (Throttle Actuator Forced Idle) and P2112 (Throttle Actuator Stuck Closed) codes. With the key ON, engine OFF, the throttle body opens and closes as it should with the accelerator pedal, and the TPS voltage reads correct. At a bit of a loss here, anyone have some thoughts on this?
