So I've been trying my hardest to address one last remaining issue I have with my 2012 Impala tune - the dreaded "clunk" coming from the driveline when reapplying the throttle after coasting/braking at low speeds (12-37mph mainly). After trying everything I could think of, I never could completely resolve the issue.
So I resorted to "drastic" measures, which so far seem to work 100%! However, I want to make sure that I won't cause any long-term issues using this method.
Basically, what I did was to put a VERY small positive value (0.02 -> 0.05) in the 0 pedal row of my Driver Demand table for the problematic speeds. My theory is that by keeping a VERY minor amount of "pressure" on the driveline at the problematic speeds, that it will basically "take up the slack" in the driveline, so that when I reapply the throttle at those speeds, the drivelone "clunk" is eliminated and all is smooth.
So far, so good - assuming that things keep going as they are, are they are potential long-term issues by having a VERY low positive value at the 0 throttle position in my Driver Demand table? Again, keep in mind that the values are EXTREMELY low (.02 -> .05) - it's certainly not enough to actually cause the car to speed up on it's own or anything....
Thoughts?
Here is a pic of my current driver demand table:
