Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Feels like I am trying to hit a moving target. Logging VE error
  1. #21
    Sep 2008
    1,668
    Yeah, it's difficult getting the higher RPM stuff on the street.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
  2. #22
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by MikeOD View Post
    Lower gears, higher hills....:-)
    On a serious note, you can use trending in some cases to help at least populate cells that are tough to reach based on lower data you have logged. One of the great things from Greg Banishs' book "Designing and Tuning High Performance Fuel Injector Systems" is the section on Linear MAP and MAF relationships. The gist is as the manifold pressure is increasing, so must the the cylinder fill...At a particular rpm this realtionship is linear, and predictable. Based on this, and if you are starting with a reasonably shaped VE curve, you can plot ot the delta slope of the change over an RPM value as map is changing and carry that delta slope across the map cells you couldn't attain....its a good approximation and gets you into the ball park. After that, logging, smoothing and hand massaging should finish the job.
    I set up a very rudimentary excel tool a couple of years ago to help with Boosted cars especially. I'll include it here but remember it is very rough...but works :-)
    Extrapolate VE worksheet stock 2004 m6 example to 199 kpa.xlsx
    Thanks,
    Ed M
    [email protected]
